BJ 42 Filter Light
Parts Unknown
Hi All
I own a 1984 BJ 42. I can't figure out how to reset the filter light.
I drained the sedimenter but the light still stays on. Any info.is appreciated.
Thanks Moe
When you drained the filter did water come out? If so. pull the plug for the tank and drain it at the source. Then add new fuel, and a really good fuel additive. If you had not water then check your alternator and brushes for output. If they are okay, look to the wiring for the filter, in the harness underneath the truck. If neither of these work, you can remove the filter take it apart and check the float.
hth's
gb
Thanks Greg
Yes, there was a small amount of water along with a small amount of sludge. I let it drain about a quart of clean fuel. Is there a prefered fuel additive that u would recomend? I just got this Crusier. I have some experence with diesels but they were military vehicles and tractors.
I love my BJ42 and look forward to learning more about it. Thanks for your help.
Moe
