BJ 40 - 24v - 1980 ... in lovely Belgium
Belgium
Hi all,
I know the Americans do not have to many diesels, but you might have a look.
Has to do with the EDIC, fuel relay, cut off etc.
I'm rebuilding my 24 volt and came across these 2 plugs. I thought I have all the parts, but apparently not.
What type of swith, relay or other am I missing?
Thanks all,
Bart
Hi Bart,
I have a 1980 Bj44,
On mine the wires and matching plugs come straight from the edic and tie into those plugs.
Bill
Bill, Hi. When you get a change can you share a picture? Does the EDIC have to separate (loose) plugs? And where is it mounted?
Hi Bart,
The edic is mounted on the block.
There is a single wire coming from the edic that is about 6 inches long that splits into 2 wires for separate plugs that tie into main harness.
Ill try to get some pictures this evening.
Bill
Understood ... so I miss an EDIC motor ... will be a needle in a haystack ...
