Birfield / steering noise
BGMachine
Working on cars I can't afford
SE Michigan
Hey all,
So my 80 started to make a noise at full right turn. I suspect that it might be the passenger side birfield. It sounds like it's coming from the front passenger side. It sounds almost like a creaking ship. I was wondering if you all could confirm that this is the birfield. I added a tube of CV moly grease for good measure, but it still makes the noise. I've attached a video and it's kind of quiet in the video (it's louder in person). If this is the birfield, does this mean it's time to replace the axle shaft? Is it ok to drive on for a few months until I'm at a point that I can tear into it? it is 236,000mile old... Thanks for the advise all.
Yes, that sounds like the start of a Birfield. I drove mine for at least 2 years sounding MUCH worse than that, but I don't do much off road.
Does anyone know why a worn birfield makes the popping/clicking sound? Is it because it is not turning freely?
I just finished replacing my axle shafts and birfields. I had the creaking ship on left turn. Funny you call it that. I called it that same thing as well as an old vault opening. Spooky I found the upper trunion bearing lost a tapered roller and it was trapped up in there. Carved out a home for it's self though. All is well again.
It's because the balls have worn a groove in the race or there is a chip in the cage. Once it starts, it gets a lot worse.
