birfield removal
ok, i read all the writeups on the disc brake conversion, but i still cant seem to get the birfields out. has anyone come up with a easier way to do it? do i want the c clips to brake or is that bad? any suggestions? please. ???
Break the c-clips....hhhmmmm..
Are you talking about the round spring clip that you can not see that is on the inner end of the axle, inside the fing birfield bell?
If so, break it, it is no big deal...
Some have used a sledge hammer while standing on the axle shaft...thought Bobby Long talked about that once...
Good luck!
-Steve
The pipe method works very good. find a piece of heavy duty pipe that is longer than the inner axle and is the right diameter for the inner axle to slide into. shove a cloth or something soft in one end. In the other end, insert the inner axle, the birfield will be sitting on top of the pipe. Pick of the pipe, and slam it on the ground(metal or concrete), the inertia of the heavy inner axle will cause the two to seperate. The cloth is in there so that when the axle drops, the splines to not get damaged. The big forking hammer trick, aka beat the living bejesus out of it trick, also works. I had to do that with one of my birfields recently. Those clips don't break all the time, but I assume you should spend the $2 on new ones. Have fun and stay greasy.
To separate the birfield from the inner axle...put a piece of pipe on a block of wood put the inner axle inside the pipe and drop the pipe on the block while holding the birfield. The pipe should be just longer than the inner axle and the pipe diameter should be large enough to not damage the birfield. Make sure the inner axle drops on the block of wood to not damage the splines.
Woody described this to me last year and it worked great.
Bringing an old thread back from the dead. I bought disc brakes for my '72 FJ55 from an FJ60 and just starting to tear into the axle to rebuild.
I need to change from coarse spline to fine spline and put my axle shaft in an FJ60 birfield. Right?
If so I have done some research and guess the "pipe" method ( http://www.birfield.com/~morgan/tech/axle/part3.html ) of removal is the best. Can I buy the spring clip local or do I need to go thru someone like SOR (http://www.sor.com/sor/cat080.tam?xax=26487&page.ctx=cat080.tam #56)?
If local, anyone have a part number or size I should be asking for?
Thanks,
Brian
Cdan may have them....I have them.
I have not found anything at a local hardware store or fastern supply center that would work in place of it....
Some may say martak...
:beer:
