Birfield problem, need advice
North Little Rock, AR
While doing a front axle rebuild I found that one of my birfields star doesn’t move freely in the cage. Taking it apart was a bear and compared to the other one it gets hung up wat to easily. The good one’s star will spin in the cage freely without the balls but the other one will not move. So, time to replace it? Or could I try to clearance it with some sand paper?
Appreciate any help. Thanks
Did you assemble it BACKWARDS? Yes, it can be done, and many have. They bind hard.
I don’t think so. I put the side with the c clip groove (on the star) on the same side with the flat (non tapered) side on the cage. The other birf cage and star goes together the same way and the star will spin freely in the cage.
It's been a while since I looked at them, but I know they can be completely assembled and put back in, then they can only turn like 5 degrees.
Do a search on birfield cage and you should get some decent pictures.
Yeah, I’ve searched and in one thread it’s said that once you start putting it back together if you can’t push one side down easily then you might have a problem. Well I tried to get it back together and it does not push down easily. And the differences of clearances between the two sides is pretty big.
Appreciate the help.
Look for the posts by @cruiserdan He KNOWS it and can point out the differences. He has stated it in one of the threads and showed it clearly.
When I reassembled mine one was easier than the other; I made 2x sure the cage was the right way up, still seemed stuck::::
kept adding moly grease and you reach a critical point and it all moves freely.
Add moly
