Birfield Joint Inspection
San Jose
Did some searching and didn’t find much in the way of inspection criteria for a birfield. I have the axle apart for a repack/service. No signs of issue before tearing it down (no clicking or leaking oil seals). When I got it down the axle had ~1/2 full of grease so they were not dry.
Here are what the stars and birfield look like. I’d say the wear mark on the loaded side is about 50% larger than the unloaded side. You can feel a slight spot on the loaded side and the unloaded side is just about smooth when you run your finger nail across it. Should I swap them left/right or leave them as they were and continue to wear this side for a while longer? I guess my hesitation is wearing the other side will increase the total backlash and maybe allow it to slap around more and increase wear? Obviously if they were clicking swapping would be the only way to fix it short of replacing. Is prematurely swapping sides going to give me anything with this amount or wear or should I keep them as they were to keep them from wearing in on both sides and becoming sloppy? Axle shaft seal surfaces look fine with no grooving.
I think it's totally your call as it looks like minimal wear even on the loaded drive side. However, I did just download your thumbprint from the second picture into my database, so I can open your Iphone whenever I want....
PS - how many miles and how was it cared for in terms of grease added through the square plug, etc?
This truck has just over 170k miles. I got it at ~158k so haven't put too many miles on it myself. I've been trying to limit it from daily around town use for wear/tear and the gas $$. When I first got it I put a RTV size tube of CV grease in each knuckle just to add some fresh grease to the system, but hard to say when it was serviced before that. When I opened it up, the lock washer on the wheel bearing nuts had been re-used and there were timken wheel bearings in it so someone had been in there before. The truck was bone stock when I got it and from what I gather spent most of its life as a family SUV. So overall I think it got maintained to some extent.
I had another thread going on the spindles. There is a decent groove in one from the outer wheel bearing inner race spinning so it might be time for one of those. Just trying to decide what else to do so I don't have to open up and clean this grease again for another full service interval haha.
So I guess if these are worn relatively minimally, that is great news as these are not cheap. Is there any downside to swapping them vs leaving them?
Alight, finally got the last few odds and ends in hardware to put things back together. Just to confirm....no reason to not re-use these based on wear right? I guess I'll swap them and hopefully got for another 60k on them.
