Birfield Inspection
San Antonio TX
OK, slowly but surely I'm getting closer to finishing my mini conversion but, still working on breaking down the mini axle, cleaning parts and rebuilding with new ones. That said, I've taken the birf apart using the "pipe method" which was fairly easy, maybe too easy, but the parts all look good and I put it all back together, My question is: how much grease do you stuff in there? I'm using Mystik brand moly grease and used approximately half to two thirds of the tub. Now the damned thing is hard to move around. Could be due to the cooler temperature (55) but not sure. Am I still on the right track....Or did I mess up?
Thanks
As long as you have put it back together according to the FSM you should be fine.
Pack it full of grease, the excess will just wipe off.
:beer:
Thanks Poser, I'm pretty sure it went back together correctly, It moved freely prior to packing it but now, hell, it won't move without alot of force. BTW, is there a wrong way to rebuild it? It seems like there is only one way it all fits back together...
really? I guess you can put it in upside down but I believe it's in correctly. any other way?
yea, you can put the inner race in up side down but when i did that i dont think i could get all the balls back into the birf because of the limited movment. other than upside down i think thats the only thing you can do wrong unless theres somthing in the bell that shouldnt be
All of the balls went in with a little push and the race is in correctly I believe because the indention on the race matches up to the snap ring on the axle. So It's gotta be the cold air temp making the grease stiff and not allowing the birf to move freely,
