I am going to repack my birfs on the weekend. Does any know if there is athread with with torque settings for all nuts and bolts? Also I have read many threads about this job and have seen a fish spring scale used on the steering arm and rotor but none mentioning the recommened setting for these.
All torque specs are in the Factory Service Manual (FSM) including those needed for the front axle service. The FAQ thread for the front axle service also should have all the torque specs. If it doesn't, look for the write-up done by Jim_Phillips many years ago. I believe his is in the "Tech Section" off the main IH8MUD page but you should be able to find it quite easily. Jim's write-up is basic instructions with no pictures.
Thanks Beowulf! I was looking under birfield before. Looking under front axle I found a thread by Romer. Is real informative with all needed torque and spring scale settings. Do you know of any Canadian parts stores that carry the rebuild items I will be needing? I read one of your threads from years ago with the A,B,C lists. Great info. Thanks, Tim
Thanks for your input! That thread had info on steering arm preload that I didn't see on Romers . I'm feeling pretty confident now. Man this site is addicting! I just can't stop reading.
