birf question
Belmont, NC
I'm new to the whole birfield thing, but have a question. I pulled both of my 80 axles apart today to inspect before installing them under the jeep. I noticed that both of the birfs have a slight play in them when you twist the inner shafts against the outer shafts. How much play (twisting motion) should there be if any in a 80 birf?
Judging by his user name, I think he is putting them under a Jeep (XJ). Is that a common swap?
Can't answer the question - it's been too long since I did mine. But someone will set you up pretty quick I'm sure.
Not calling an 80 a jeep...
Your right marc311, I'm putting a set of FJ80 axles under my Jeep Cherokee (XJ) Not a common swap. I still havn't found anyone who has done it before but i'm sure it will be a nice upgrade from the dana/chrysler axles.
Any info on these shafts would be great. I've been searching for a while now and learned alot but havn't found anything on acceptable play in the birfs.
You may want to post it in the 60s forum as well. Although I don't think they are the same axles, it is the same design. They might even be the same axles.
Also, do a search for an online FSM. I know the FJ60 FSM can be found online. I'll bet somebody posted the 80 service manual as well.
No 60 axles and 80's are different. No common parts.
Yep he is installing 80 axles (SF rear) under a jeep. Not a common swap over here, is in Japan, but makes sense if you can get them cheap.
I think an even swap for my D30/Chry. 8.25 axles could be considered cheap...
Yeah that is a great swap especially since you can get both those jeep axles for about $140 at any pick a part
well, they had lockers in them and HD diff covers but other than that they were pretty much stock. Still think it was a good trade.
so back to my original question, should there be any play in them or should they be tight like a u joint?
Little bit, but not a whole bunch. The best way to evalueate the Birf is to take them apart. There are several thread on this in the archives. Then you can look at the inner bell and star to see how much wear you have. You can also look at the cage to see if it has any cracks and to repack them properly.
