Birf question
Belmont, NC
How much play (twisting motion) should a birf have?
I'm more used to u joint type axles and know that they need to have none at all, but when i pulled my front 80 axle apart the other day i noticed some play in the birf.
Are you talking about play between the inner and outer axle rotationally? If there is a lot of play there then you need to separate the joint and inspect the splines.
