Birf party.......
Falkland Islands
= sore body...
well after 190k miles :eek: I figured it was time....the findings are the passenger side was alittle low on grease with some signs of over heating as compared to the drivers sign which appeared to be normal based on some of the previous posts.....the knuckles have been serviced at the dealer as I am the second owner bought with 45k on the clock. There was no cross contamination with the gear fluid so the inner seals held up well on both sides.....If you are taking on this job my experience is have lotttttsssssss of shop towels on hand to clean all the parts, this was the time consuming part of the project cleaning all the parts for reassemble..
some small notes:
have some razor blades or a sharp chisel to scrape old gaskets off
have a bleeder hose for caliper because you will want to replace rotor and pads
use 100 pads way better...make sure you push the pistons ALL the way in
make sure you break loose the hub bolts to the rotor before you remove the caliper...put a screw driver in the top of the rotor and wedge in between the caliper
BUY YOUR PARTS FROM CDAN!!! just open the box and everything is right there...plus save money...THANKS CDAN!!
thank ROMER for the FAQ...
and good luck.... it took me the weekend taking my time...:beer: :beer:
Andy
Can someone send me the contact info for CDan. It sounds like he is the TLC god, and everyone seems to reference 'him'<? but never post a link for others to use. Sure do appreciate it!
