Last weekend while dissassembing the front end I noticed that the birfs were a little hard to move while I was trying to rotate them by hand...... I had one hand on the birf and the other on the inner axle and it was pretty hard to rotate...I had to give it a light tap with the inside of my palm so it can move.. I thought it might be because of the old grease still sticking into the inner cage/balls, but it stills seems kinda odd.. I have a spare set of birfs from a '97 still attactched to the inners and those things move and rotate with no effort. I forgot to mention that not only do the my cruiser's birfs require more effort to move than my '97 spares, but they also seem to have a little play when I rotate the inner shaft and the birf in opposite directions.......
Well, I know what I have to do, take the birfs apart and look for scaring/marking/cracks inside the cage/balls... I will be most likely swappimg the insides of each birfield.. My question is, if everything checks out when dissassmbling the birfs, does this mean that these birfs are good to go? I mean, does this slight play and extra effort required to rotate the birfs mean anything? As mentioned before, it has been a couple years since last birf job, so I feel like I don't have clue as to what's right between the spares and the ones from my cruiser... Any input.....? Thanks inadvance........
