Birf Job - Two week checkup with some questions...
Poppped both sides off this weekend to double-check my bearing pre-load. I'm assuming it is normal to have some moly work its way out to the snap ring via the spindle/axle shaft? I made sure my spindle bushings had plenty of grease available to them during the service. Perhaps I used a bit too much. DS was fine but the PS had more than I would have expected.
Wheel bearing pre-load dropped from the high-side of 12lbs two weeks ago to about 7.75-8.25 lbs which surprised me. I didn't expect that much of a drop but its within spec so I didn't touch it. I'll continue to monitor and check it again in a month or so.
Knuckle studs/nuts are still nice and tight. Lower brake caliper bolts were surpisingly not as tight as they should have been. My friend torqued these down initially so maybe he just didn't get them tight enough (90ft-lbs). I know there have been some caliper bolt problems so I'll be monitoring this frequently. Only my top caliper bolts have washers which I'm assuming is correct? Anybody know why this is? I found this odd during the tear-down but neither side had a washer on the lower caliper bolt so I figured it had to be "correct."
Thanks.
--Mark
Thanks.
--Mark
