Birf grease question
Kelowna, B.C.
I drilled, tapped and fitted a nipple on the grease plug of my fj40 and would give it 4 shots of grease every oil/lube interval, this worked great. always had a film of grease on knuckle and when serviced birfs they where not to full.
That being said this was not a full time awd vehicle do you think this setup would over lube the knukles on an 80?
Edit: ok so its been a while since i serviced the birfs on my fj40 (15 years) I read the manual and the diff housing ball is not sharing the same grease as the birf (from what I can tell) so when grease is added through the plug it only lubes the ball and not the axle cv joint....... is this correct?
