I'm about to re-wire my whole 40 with one of those EZ Wiring harnesses. It doesn't look that difficult but back when I installed a brand new alternator I hooked up a wire that wasn't hooked up originally. It was just dangling there on the back portion of the alt. So, naturally I hooked it up to the battery. Everything worked great. Before as soon as I turned on my lights everything would die. Now, there isn't any issue what so ever after replacing my alt with #2 wire hooked up. However, the issues I am having with my fuel sender might be caused by this #2 wire hooked up to the battery from my alt. There is another wire coming from the same place that #2 wire originates, wire #1, that probably runs down to my coil but i'm not sure. I have attached a pic to explain a little.
I ask this question because in the EZ Wiring instructions it states that if you're running an alt with 80 or more amps you need a bypass wire. Any help would be appreciated.
