For almost a month, I had to contend with a binding and "tugging" sound every time the 8o makes a turn specially when turning from a decent. Tightened, greased and oiled every moving under-body parts, except the brakes of course, but the sound did not go away. I thought it was time for new bushings and brought it to the car shop for the purpose.
The bushings were still good and the shop merely re-tightened everything but this time using wrenches with extended handles. They tightend all the nuts and bolts of the Radius and control arms, lateral rods, stabilizer bars and everything under with big nuts and bolts.
While that appears to have solved the problem because the sound went away, I am still wondering if that was the proper remedy or will the overtightening later develop some new problems?
I suppose they tightened it to at least 150 lbs. Is that Ok?
The reason I am asking is because I just want do it myself the next time !!!!
Thanks in advance
Thanks in advance
