Bf Goodrich ko2
What year cruiser? What size tire?
On my 02 the stock size isn't as common so you need to adjust a bit.
Either way they are readily available you may just need to order them in.
Where can I buy KO2 for my land cruiser in stock?, it seems nobody have them, thanks for the help.
EVERYWHERE
Thanks, so far nothing until november.
Really doubt that. Still haven't mentioned tire size or vehicle year .
Stock size of 275/70-16 are usually backordered and that's prob what your referring to . This size is not as common and I think are D rated. I ordered a set from Toyota service department when I first got my truck .
You can switch over to a 265/75-16 which is more common and readily available and is suitable for the truck.
If you have post 02 I think they have bigger wheels and idk whay the size is but I'm sure there are many many k02s available
Mine are 275/70 R16
Found the ones you mention
I need two can I use 2 265/75-16 and 2 275/70-16?
I wouldn't mismatch size on an AWD vehicle and most tire shops prob won't install.
