better airbox
The 12HT breathes less than the 3F and 1FZ FE, but they all use the same airbox.
Probably not an option for you but....
Unique Metal Products (UMP) Home Page
I have ran one of their air boxes in both a v8 swapped truck and a diesel. Excellent product but they are large and expensive.
Cheers
So you mean there won't be much of a difference ?
Not unless you plan on spending a lot of time at 4000+rpm. I think the Landcruiser airbox has extra capacity built in to allow the filter to go for longer in dusty conditions.
I think the HDJ78/79 has a slightly larger airbox, but I cant see the point of spending up big to get one when your engine doesnt breathe hard enough to use. A 12HT does its best work at 2500 or so
There are calculators for airflow engine cc
The other reason is the Toyota filter and box takes up a bit of room, anything with more flow would have to be bigger. Donaldsons have a range of filters that have higher flow rates but are more compact. Im not sure if there is anything in the correct size though
