What is the best way to clean out the inside of the FJ60 frame, while it's still under the truck!
I've searched and read a lot about varied frame restos and repairs.
Seems like some people stand their frames up vertical, and all the rust, dirt, sand, etc. comes out one end.
Others have cut open their frames, cleaned up the inside, then re-welded them back together.
I stuck my finger in one of the outer frame holes (under the B-pillar area of the body, along the vertical side of the frame) and felt a bit of crap.
There's sand, rust flakes, etc. I need to suck it out. Shopvac with a garden hose? Seems like it might get frequently plugged with rust flakes. Also, it's hard to get in there.
I'm thinking about attaching the shop vac nozzle to one frame hole, then pushing everything towards it through another hole?
Or run a cable through the frame with a small washer on the end to plow/scrape crap to one central point?
Run a garden hose on the shop vac in from one end of the frame, and poke at it from the other?
It sucks that the frame goes up over the front and rear wheels! There's crap stuck down in the valley.
BACK in the day on the LCML, I remember someone suggesting the shop vac method?
Have the great minds of MUD improved the methodology?
