- Thread starter
- #21
I'm nolonger a fan of my electric grease gun. I can't tell if I got the joint properly greased so I'm back to using a lever action with flexible hose.
Really? I see grease coming out of all four cups so I assume it's greased well.
I'm now using John Deere SD Polyurea Grease everywhere. It is what JD initially uses to lube u-joints at the factory. After starting to use it on my toy's u-joints the pressed out grease is looking cleaner than ever before. They do have one that might be better for ball joints, but it's not likely all that much better. Oh, it should be about $3 to $4 a tube now with the increase in oil prices. The other thing is if you haven't been using a polyurea based grease then you want to clean out all the old grease before using.
I may try that grease out. I've been using synthetic grease exclusively for the last 12 years with great results. My last set of ujts lasted nearly 12 years on my other 4x4 which is a frequent water/mud truck (like 2 ft of water/mud slop) . Greased after every outing.
