Best flux-cored mig wire?
The thicker wire allows more voltage to pass. Making the machine "more powerful" It has nothing to do with melting the flux. That happens before the steel melts
anyway.
OK. What is happening ,is when running FC .35 at full voltage (tapped @ E setting) the breaker blows. I have to turn it down to C setting for it not to blow.
I can run .30 with gas @ E setting and the breaker is OK
Note; where this is happening is in an old Sawmill . From closer inspection the breakers are 15amp @110. The Lincoln needs 20amps @ full voltage
Well instead of running back and forth to the Breaker box , I picked up a 5000w 10hp Diesel generator . (oriental)
