Bent Tie Rod
Beaverton, Oregon
I knew I wasn't imagining the wandering in my steering after that last trip to the trails!
As we were installing my new MetalTech sliders (:bounce:), I noticed a shiny gouge in the tie rod (behind the front axle) where it was bent up by a rock and pushed into the input of the front diff. The tie rod is still bent a bit and causing my front to be toed out a little, but not very much.
While I figure out what to do with this, is it possible to adjust some toe back in with the bar bent? I haven't really gotten under there and tried to move it yet.
Most of the old threads I could find were several years old.
1) Do most of us still go with the Slee DOM rod?
2) After 185K miles, are new ends reasonable PM when replacing the rod?
I'm tempted to just pull the bent, but useable arm, ends and all, and keep it for a spare so CreeperSleeper doesn't have to resort to welding a HiLift handle in for steering arm next time. :doh:
Slee's are good, as are Marlin's and BudBuilts as well.
I've bent Christo's before and reinstalled a new one from him.
Everything, to a certain degree, is breakable. :D Replace the ends while you are at it. It is reasonable cost wise and you are under there, might as well.
I used the bent tie rod I took out as a nice long and heavy duty breaker bar.
Great double duty action! ;)
-o-
I'm going to talk with a guy from our local club who built some DOM rods for another guy and check some other prices before I pull the trigger. Is there much of a difference in price/quality between the ends Slee sells and the OEM stuff from Dan?
I'm certainly not expecting an unbendable replacement, but if you are going to pull the OEM rod out of there, it seems logical to add a little bit of beef to the replacement. The rock I hit didn't seem like a really hard hit, but I suppose it doesn't need to be when the weight of the truck comes down on that one bar.
By all means, change it. With any kind of bend in it, it's strength is greatly reduced. You can build a new one with the old one by cutting the ends off, at least 12" or so, and welding them into a larger piece of tubing into which they fit snugly. I have done this with a bent one from my 40 and carry it as a spare. Be sure to let the slotted/threaded ends protrude from the end of the sleeve tubing prior to welding to allow the clamps to be installed.
BTW, Toyota sells the tie rod complete with new ends, you cannot buy just the tie rod. (At least for the 40 it is that way.)
I have an extra budbuilt one in my garage. If you were closer I'd tell you to swing by and you could have it. Bud is a super guy. Personally though I prefer the stock rod. Why? Well, it's an easy to replace fusible link. Hey, chances are if you bend the rod you were doing something you shouldn't have been - if the rod doesn't bend something else will have to give. swapping it out on the trail if need be is quick and easy if you have a spare with you. If not, you could prob get by with sleeving the bent rod with the handle from your hi-lift if need be.
Jeepers have the option of a tie rod that will bend, and then bend back. Do you guys think there is enough market for someone to build these for Toyota?
