Belt turned inside out
Valley Springs, CA
First time seeing a belt inside out.
Guess I need a new belt. Maybe do em all at the same time. Anything I should know about a belt being this loose? I can slide it back and forth by hand . . . easily. Drove with it like that for up to 50 miles.
That's its way of saying its a fogged belt and doesn't belong in your 80 :)
I'm a fan of Toyota belts and the alternator set is a matched set that should be purchased together.
If that is just the AC belt you will be fine. Maybe not frosty cool but you should be fine. Order up a new set and make an hour project of it.
Replace them with all Toyota Belts. Mine sounded like it had a supercharger with the aftermarket grooved belts.
2 fan belts Toyota Part# 90916-02353-83
1 AC belt Toyota part# 99332-10910-83
