believe ABS not working properly
Brownsville,Tx.
I am not too sure yet but my theory is that the ABS is not working as it should.
my truck is a 93 and is making like snoring noise on occasion. The more I drive her, the more often that it does it.
it was working fine until Tuesday, I pulled a trailer w/ a not so heavy load. it was may be 2000-3000 lbs easy for my girl.
I did use the low and the abs disconnected just fine. The load was moved for less than a mile. After I drop the load I went to hi, everything was normal for about a 3 miles. Note: I was still pulling the trailer w/ no load.
The truck started making some sort of a snoring noise. I press the brake and it felt like the abs was working.
As I slow down to a complete stop, the noise will stop. I will start driving again and no noise.
After a few miles, it will come back. All this w/out the ABS light on. Later down the road, it will do it again.
I would stop and while braking I felt like if the ABS was working. I would stop and then the noise will go away.
I tried picking up some speed and then hitting the brake hard trying to see if the noise would come and at the same time trying to send brake fluid w/ pressure hoping to get rid of the noise but no luck.
one time it pulled to the passenger side. I check the wheels and they are at normal temp.
where do I start w/ this?
ABS light only came on once. as it is, at this time light is off.
I drove the truck in reverse thinking that may be the ABS is trying to engage or the 4lo is still trying to engage but I don't think that's the problem since when I engage 4lo the ABS light comes on. I change to 4hi and the ABS light goes off.
I took it to shop and they did not have a computer to read any codes,
how can I read the codes besides going to a dealership?
thanks
JP
