Before Alignment racks...
Today we have computers and laser sensors to help guide us align our suspension systems on our cars, now I'm wondering, before computers, how did one align the suspension on a car? I just realized I never asked my autotech teacher this question. I ask this because I'm wondering if it's possible to align your car these days without an alignment rack.
On our 80-series, set the toe at 1/8" inch with a steel tape and you're done.
On an 80, yes. Look up "Tape measure alignment" in the search. The only thing that is adjustable on an 80 is toe in and the steering wheel.
I did a tape measure alignment job on my wife's truck when we changed the suspension and TREs. I didn't bother to straighten the steering wheel because I wasn't sure about how well I got the toe. I set it to in 1/8th inch.
So... After a month of letting the suspension settle, I took it to the shop. It was 1.90 degrees of toe. They straightened the steering wheel (tie rod), charged me $70 and sent me on my way.
So, yes, its possible. Should you do it? Thats for you to decide.
YMMV
We used alignment plates (think of a heavy duty lazy-susan) that had graduated tick marks on it, and a caster/camber gauge with a bubble level in the middle. The gauge mounted magnetically to the hub (or a wheel bracket) and showed the degrees of camber. For caster, you took the spread between the two wheels after turning them lock to lock. One drop of the gauge on the ground and you had to sent it out to be calibrated:mad:
Pretty crude by today's standards, but, you usually had mechanics that knew their stuff. Now many shops use hi tech racks that even show the "mechanic" where the adjustment points are.
