Beeping sound
In my test drive, I spinned the knob to the Lo option and the car started beeping. Is that normal ?
It's normal if you try to do something that doesn't work - it will beep if you try to put it in low from any shifter position other than neutral, or if you shift out of neutral before the electronic transfer case has completed the transition from high to low.
oh that's why.
