Hey everyone, I have been lurking here for awhile and researching the 200 series. My wife and originally really wanted to save up and get a 2013 but her 2006 Sequoia was in need of some real work and tires sooner than later so we ended with a 2008 LC with fairly low miles (110K). Im not super new to Toyotas, I currently have fairly modded 4.7L 4th Gen 4Runner that we have been using for family offload trips and pulling our camper (20 ft Palomini 4K fully loaded). The 4Runner pulls it great until I get into that western KS cross wind and it puts so much drag on us that I can't keep the 4Runner in 4th gear and end up shifting between 3rd and 4th causing the trans to get much warmer than I like . My goal with LC is mildly built truck that will pull our camper and run mild to moderate trails in Colorado, we vacation every summer in Lake City and Ouray area.
Question, when I got home with LC (9 hour drive) I noticed a substantial driver side lean (1" to an 1 1/4"). The LC was a Texas truck its whole life so there is hardly any corrosion on it and I was able to get the KDSS valves to break free without too much work. I followed the instructions from the Australian guy in the youtube vid but I didn't notice any change in the lean at all. I used an old land scanning timber that I had left over which is similar in size to a 4x4. Is there any other methods I can do to try to get the lean out, should I use something taller and try same method again? Has anyone here had their KDSS system "recharged or bled out" if so how much did that run out the dealer? I hopefully won't need to replace any parts unless a leak is found I guess. I plan on running it in to the dealer for a 100K check up anyway. If anyone has link to the KDSS that I may have missed or advice it would be really appreciated.
Thanks,
Travis
Thanks,
Travis
