Beefed up Hellwig sway bars for 2007(?)-2016 LC200
SF Bay Area
Has anyone seen or tried these heavy duty sway bars? Any thoughts on improved cornering or reduced roll?
Hellwig Offers Sway Bars for 2007-2016 Toyota Land Cruiser - Off-Road.com Blog
Visalia, Calif. (December, 2016) – Hellwig Products, an industry leading manufacturer of towing, hauling and performance suspension products, has released its new front and rear sway bars for the 2007-2016 Toyota Land Cruiser 78/79 Series and 200 Series. Hellwig’s new sway bars are the quickest way to improve both the handling and safety of the Land Cruiser.
The Toyota Land Cruiser is one of the most popular SUVs ever built thanks to its classic Toyota reliability and its capabilities both on and off-road. Though Toyota equips the Land Cruiser from the factory with a front and rear sway bar, they are undersized and not capable of providing adequate roll control while towing, hauling, especially in heavier, armored applications. With the addition of Hellwig front and rear sway bars drastic improvements can be made to handling and body roll control, making the vehicle safer and more capable. The increased anti-roll rate of the upgraded sway bars helps compensate for the additional weight from vehicle armor, heavy loads, or the higher center of gravity on lifted vehicles.
Hellwig’s upgraded sway bars are forged from heat treated 4140 Chromoly steel. All four sway bars for the different series Land Cruisers are shown in the table below. Each sway bar is finished in Hellwig’s “Hammertone” powder coat for all-weather durability, comes with upgraded polyurethane bushings for noise-free operation, and reuses the factory end links and mounting points making installation a breeze.
P/N Description Diameter
7753 Land Cruiser 200 srs Front Sway Bar 1-1/2”
7754 Land Cruiser 200 srs Rear Sway Bar 1-1/4”
7755 Land Cruiser 78/79 srs Front Sway Bar 1-5/16”
7756 Land Cruiser 78/79 srs Rear Sway Bar 1-1/4”
Hellwig sway bars can be installed in less than an hour with simple hand tools, come with all necessary parts and hardware, are made in the USA and come with a Lifetime Warranty on all steel parts. For more information on Hellwig’s Land Cruiser Sway bars visit www.HellwigProducts.com.
Do you have a non-kdss 200?
By that I infer you have knowledge these cannot be fitted to a KDSS vehicle. I have KDSS along with all other USA OEM purchasers of 2016 LC200s to my knowledge. Seems like an odd thing for Hellwig to pay for a U.S. press release and for the R&D given the prevalence of KDSS these days.
Didn't look where you were located....I emailed the hellwig engineering department...reply as follows:
Unfortunately it will NOT fit with KDSS
Ben Knaus
Director of Engineering
Hellwig Products
Mystery solved
