BEB numbers on 1HD-T
For all those who have replaced their bebs on the 1HD-T engines. have you noticed the bearing you removed to have a number stamped on them? I believe those numbers are used to get the correct sized bearings to get your oil clearances. I doubt new bearings from 3rd party such as ACL or Taiho would come with any sort of marking. So what I'm trying to get at is if the oil clearances are too big or small get thicker or thinner bearings and the worst case scenario is to grind the crankshaft?
