Battery
Alpharetta GA
My battery seems to be going on me. The water level was slightly low so I topped it off with distilled water. By the way it appears to be a Toy factory battery, it has a Panasonic logo on it. But it has died on me twice since then and the viewfinder deal is showing charge. I let it run for about 30 minutes and it is still showing charge and my voltmeter is registering correctly. My question is what size and cca's do I need to look for and what is everyone else running out there. My not too distant future includes a winch and stereo equipment later. I have had red top optimas before but I can get a pretty good deal on a Acdelco battery since I work for GM. What dual battery kit if I decide to go that route would everyone recommend? Thanks as always!:cheers:
Wrangker NW Power has a slick dual battey kit that includes everything you need including the second tray and the Slee washer bottle relo. kit. I believe our size is a 27F but 24f also fits. You could also go with a Exide Orbital #EXP34XCD (Like an Optima) from www.4wheelparts.com they are $121.99.
Right. 27s will work as well as 34s and DT78s as well as 65s. I presently have a 65 with an 800 CCA on my truck and it works and fits well.
Also, you might want to check out Odyssey batteries.
