Battery shorted, causing burned charge wires?
The NW, Cascade Mountian Range
i have discovered that my Exide Orbital POS battery will NOT charge up. I took it to work, and put it on our Snap On D-TAC, a starting and charging system analyser.
I put it on multiple charge modes, among on was a 60 Amp charge. it was charging for less than an hour before the battery began smoking, or steaming hydrogen, i dont know which, out the vents. i used the infrared thermo meter to check the temp. it was 175° F!!!
so, it is junk, and will not charge up.
after three days of attemps i am sure of this.
in the past, while having this unknown bad, but recently jumpstarted battery, my wire from the alt to the 80 main fuse, and then again to the batt terminal was getting so hot to the point where the sheild was melting.
i now know the battery is bad, and have not yet replaced it.
does it make good sense the cause of the wire burnin was caused from the battery?:eek:
thanks.
Sounds like mebbe you're having a voltage regulation issue. Do you have an internally or externally regulated alternator with that truck?
WristPin said:
internally regulated.
i made the grave mistake of swapping out my OEM on when i replaced it it with lame Napa parts.
this is the third alternator in 5 years.
I'd test it. I'll bet it screwed your fuse, then your battery discharged and croaked.
Ha! Quoted before you edited.
I've been burned with non-OEM alts out of the box. Haste makes waste.
the fuse was not blown, but i suspected possible excessive resistance, tho.
thru the window, of the fuse, i saw minor green corrosion.
so i replaced it with OEM a part. and still the problem persisted.
WristPin said:
at the time i werked for NAPA, and was happy to sport napa parts.
NAPA is great for a great many things. But in my humble opinion, alts are unique, and your best bet's OEM, even at twice the price.
Twill be interesting to see what your tests show, but I've had a bad alt that bench tested OK, but was fubared on the truck.
i agree. now that i know how much better off i was if i had just replaced the brushes, or what ever, i dont buy non OEM starting and charging parts, anymore. Napa does sell many other good stuff, im not knockin them, just havent had much luck with Rayloc (the company who rebuilds thier stateres and alternators)
once i put a battery in it, i will take it to work and use the D-TAC on it and see.
just the smoked wires really boggle my mind. could be relative to charging, or could be the starter switch...
i know for a fact it is not any of the EFI wires shorted out.
i unraveled and inspected every wire.
that was lame.
