Battery not holding charge
Tallahassee
My battery died a few days ago. 2 days before dying, my alternator light did flicker and I read slightly higher voltage for just a few seconds. I went ahead and replaced the battery knowing that was most likely not the issue, but because it was several years old and looked rough. Truck cranked up fine with new battery and ran great for 3 days. On the morning of the 4th day battery was dead. Did not even try and crank.
Just curious if anyone has had that light flicker and the problem not been an alternator. Wiring looks fine although I have not metered any. I'm thinking tomorrow I will replace my belt, and regulator; brushs as well while battery is charging. Then if necessary my alternator.
Just like hearing others inputs as my gut is telling me it's not an alternator.
One other thing, with key turned but not cranked before battery was dead, my alt/voltage light was not on like it was supposed to be. Replaced charge fuse and fixed that. Battery still ended up dying 2 days later.
Thanks
