Battery Level
Does anybody know what battery level should your FJ be at? Mine seems to have dropped down significantly since I bought it. Pictures of the guage would be appreciated.
If you have the stock battery it tells you on top if it needs water, charge etc. Old school acid batteries rule of thumb was the water level was to be kept at the lower plastic piece of the fill spout. you should use distilled water only , use tap water if thats all you have access to. gel batteries for obvious reasons you cant do anything with
I think MelFeliFJ means the voltmeter - which should read around 14.
Carl
