Battery Installation
Hi all,
When I installed the new battery tonight after the old one went dead, stupidly I installed the positive end first then the negative.
Did I cause any damage by doing so ? should I re-do the install by taking off the negative first then positive and re-install in the same order ?
Note: I did not realize this until I am about to go to sleep, and of course I had already started the truck at the time and was fine.
Please advise.
Thanks
Hi all,
Please advise.
Thanks
If Im getting this right you are worried about the order that you installed the termnials on the battery?
If this is correct dont worry, you did just fine. :)
hth
ken
Your flux capacitor will not have the right polarity. Sell the truck.
You can fry stuff pretty quickly hooking the wires up to the wrong terminals (positive to the negative, etc.), but it sounds like that was not what you did. It sounds like you were worried about the order you put the cables back on. Don't stress.
I take the negative off first, and put it on last. That way, if you get the first cable installed and you accidentally bump the loose one into metal, it isn't the positive cable grounding out somewhere.
Thanks guys, I appreciate your feed back and humorous comments.
Yes I was worried about the order in which I had installed the battery terminals last night.
I took them off the old battery in the correct order (Negative then Positive), then on the new battery I installed the Negative first instead of the Positive.
Thank god this is not going to cause a problem.
Thanks to all again
