Battery Failure
Okefenokee, GA
So, my mom's golf cart died coming up the hill at the back of her house and as I couldn't get any friends to help me push it, I decided I would winch (Warn XD 9000) it up the hill so I could get it into her garage. It was dark when I started and turned on my off road lights (4 IPFs...two on top and two on the bullbar). After about 30 seconds my engine sputtered and shut off.
I jumped the battery off with my pickup truck, but the engine kept dying and i eventually had to keep one foot on the brake and one on the gas to get the cruiser moved to where I needed it (with 40 ft of winch cable out). The next day it would not crank and I hooked my pickup up to it via jumper cables and pulled the winch line in while my mom made sure to keep the RPMs up in the cruiser.
I then hooked up a battery charger to it and let it sit overnight until it read fully charged. I unhooked the charger and the cruiser would not start again...starter wouldn't even make a sound.
All the interior electronics and outside lights still work.
My question is, does this sound like I've only killed my battery or did my alternator go as well? Or, is there something else I may have done?
TIA,
SJ
If you winch without keeping your RPM's up, it's a quick way to kill your battery.
Local club member did that last winter to his.
No other damage than that?
I'm on my way to get another battery anyway. I guess that's the first step in figuring everything out. Thank you guys for the replies!
SJ
Get yourself a Sears die hard and be done with it. :D
Your battery acts as a buffer in your whole electrical system. No battery, no buffer. That's why running without a battery isn't a great idea, the alternator can put out a spike of power and damage something (power surge), or put out too little and damage something (brown out).
You are probably fine.
x2 on the Sears Marine Die Hard, btw. Excellent price for either the PM-1 or PM-2.
What you need is a voltmeter first and foremost. Since you charged the battery, you should be seeing 12+volts just sitting there. When you crank it, it will drop - but not much. If the battery won't hold 12V sitting or drops under about 11v under load, it is bad. Once the engine is started, you should be seeing 13.5+v or so. If it isn't, you're charging system has issues.
If both are good, but it isn't cranking you likely have a problem with your cables/connections or starter.
If you just replace the battery, you will kill the new one too if your charging system isn't working. And if your connections/cables are bad, a new battery won't help either (unless you fix the connection when installing the new battery).
You can get the old battery tested as well. But even if it is bad, you should check to make sure your charging system is putting out sufficient voltage once the new battery is installed.
In other words, nobody here can actually tell you for sure what is wrong. With a cheap voltmeter, you can figure it out and know 100% (or at least focus in on the problem area). It does sound like you killed the battery. Your charging system at least partially works because you could keep the engine going by gassing it. But really, I would think once you had the engine started you should of had enough juice at idle (unless your aux lights were still on).
