Hi
1996 4Runner 2.7L auto.
Battery drains in 48 hours or close to that. I put a clamp on ameter on the white + lead to the fuse box and started pulling fuses. Removing AM1 arrests the battery from draining now.
Originally it seemed fairly straight forward..either an ignition switch or a starter relay... but I read somewhere that a guy had to repair wiring in his rear window..
anyone run into this problem? I assume something is leaking to ground and if it gets bad enough it can even blow the 40A AM1 fuse.
thanks for any direction or experience on where to look first. Or where to find a detailed wiring diagram. Couldn't seem to find it in the 96 manual at the top of the threads here.
