Battery Charging ???
Golden, CO
What size wire is best to run from the alt to the isolatero? I've got some huge 4g but won't be able to run a circuit breaker or "fusebile link" on that. I also have 10g and would run a 14g fusible link.
Also, heard talk of using a maxi fuse somewhere in line....where does that go? Thanks. Dan
Dan, the fact that you're even *thinking* of running 4 gauge from the alternator makes me nervous (complete overkill). Seems like you're grasping at straws. Though I am glad you're asking here before you put you and your rig at risk :) .
Wire gauge depends on your peak alternator output. Assuming alternator is OEM and less than 100 amps, less than 5' run to isolator.. run 12 gauge. Solder and shrink both terminals. If we're talking about your V8, that 10 guage will afford you 150 amps peak.
At the very least, fuse the supply into the cab. Add up the potential draw and fuse accordingly. The fuse should be rated for less than the capacity of the wire you run (common sense). Now.. there's one drawback to using a fuse over fusable link. A momentary short will not cause a fusable link to fail.. it will, however, blow a fuse. So to that end, cary spares!
If you have any accessories that are wired outside of the main fuse block, you'll want to fuse those as well. Waytek has some great inline fuse holders that take ATO and maxi fuses (please do not use the 3M self stripping ones!).
The key to automotive wiring is knowing wire capacity and potential areas of fault. The rest is common sense.
Use a gauge -> amp capacity chart to determine *what* to use. The chart should cover run lenths (accounting for voltage drop). Fuse at or less than capacity. Most of these charts are pretty conservative so it's ok to fuse at capacity (i.e. 25 amp fuse for wire rated at 25 amps @ X feet). Any time you raise the temperature of wire, you push it closer to capacity. So there are situations where you need to "over wire". When possible, keep runs short, keep bundles small, and keep wires away from heat.
Fuse prior high fault areas (like the cab.. tons of places for a short). For short, simple runs like battery -> starter, etc, just make sure you *protect* the wire by routing it out of harms way (within reason.. don't make run too long), applying spiral wrap/ split loom to minimize damage from rubbing, fluids, heat, etc, etc.
Feel free to PM me.. I'd be more than happy to supply my cell # so you can call if you get in a pinch.
The reason I mentioned 4g wire is that woody had mentioned using it at one time...not blaming you woody, just an observation. I plan to run 10g from the alt to the isolater and 10g from the iso to both batteries. I will solder and shrink the ends. So I have some in line fuse holders/cicuit breakers, my schematic calls for one inbetween the iso and aux battery and then I will place another between the alt and isolater--where do I get the charts to know what size fuse/circuit breaker I need???
Thanks a ton for your help. I just want to be sure to wire these things up properly. The maxi-fuse holder I have is connected to 6g wire--seems a bit big and I can find the wire the takes power to the main fuse box--does it come off the starter??
I am going to run a aux fuse box off the 2nd battery. Do I need to use a larger guage wire for the main feed or is 10g adequate?
wire table (end of page)
If I'm not mistaken, maxi fuses top out at 80 amps.. 6 guage will easily push 200 amps. If you're fusing battery leads, check out the "mega" fuses offered by Waytek, et al.
Stop asking what gauge wire to use :).. It's application specific. Determine max load and then determine required gauge.
got it. Thanks
