When my battery died, I decided to upgrade to a Exide Orbital. I picked the Exide Orbital because it was commonly available--- and I hoped that because it had center posts, the stock battery cables would reach it.
Well it turned out that my cables did not fit it. The positive was still about two inches short. The negative fits, but is streched tight.
So I decided to make a cable extension. Originally, I wanted to just make a two inch extension. The problem is that the individual cable lugs are 1.5 inches a piece, so I couldn't make one that short. So I made a ten inch extension, and curved it around. I also used the miltary style battery connectors, so I could attach a second cable for my winch in the near future.
Anyway, I am not completely happy with the result. Does it look ok to you?
Should I be concerned that the negative cable is tight? I have considered cutting the end off and extending it some in some way.
I may just break down and make all new cables, although I would still have the issue of a short fusible link. Also, it appears as though the negative battery cable uses some 90 degree lug at the engine. Where can I get one of those?
Thanks
Jared
Thanks
Jared
