Battery cable clips???
Do the battery cables have any clips that holds them off the frame? Mine are just hanging down sitting on the motor mount. Im about to swap em out to a heavy duty set from fourrunner, so im not sure if the factory clips would fit the bigger cables but i cant imagine a hot cable sitting on the engine mount is good idea. 97 lx450
The factory clips are a curved piece of plastic about 3” long with a clip that locks into a hole. The battery cable(s) lay in the groove and then secured with harness tape.
Ok i see one on the inner fender behind the battery box. And i see a "stand off" on the block where one may have been?
And are those available from the factory? I cant find the them on the breakdowns
Heres where im missing one i think
I think someone posted a Toyota wire clip/clamp holder part number sometime ago. I believe people were looking for a replacement for the main engine wire harness clip/clamp. Maybe it was used on a Supra? Hard to find that needle but it's in there
I was thinking of using one of those clamps in lieu of 'proper' clamp. Just a thought
but i dont see what i need, am i missing something?
The number on the clip, I believe indicates inner diameter (i.e. 10,13 etc). Option 1 - measure the loom with calipers to know what # you need. Then go to the junkyard and stock up from pretty much any other Toyota (camry, corolla, mr2, 4runner).
Clip part #'s all use the prefix "82711" and the rest of the number is stamped on the clip i.e. "2A620". Same with all wiring connectors, but using prefix "90980". Option 2 - look at another FZJ for the correct part # on the clip you're missing and add "82711" in front - you can then order from the dealer. I have an HDJ so can't help out. Most likely the same part # indicated in the thread referenced: 82711-2A620
Here's a youtube vid showing easy removal:
Good luck.
