Batterie Problem please help
Georgia, Tbilisi
Hi guys, I have a really strange problem
I have a HdJ 80 1994 with two batteries, Today I checked if alternator was chargin but surprise, alternator is charging just one of two bateries b 1)= 14v and not charging
second one b 2)=12v
can you tell me if alternator must charge two baterie at the same time or not?
Today i went at work 2 km with the car, stoped engine and then after 15 minutes i tried to start it but it didnt, few minutes after i tryed once again and it worked alone. really strange
are my batteries dead or .......
thanks.
ps i cheked the alternator was charging properly only one baterie when engine ideling.
Well is your truck 12v or 24v, gas or diesel? IF its 12v what are you using as a battery isolator?
its Turbo Diesel 4.2
i think its 12 v, (i instaled aftermarket radio wich was on my toyota camry 12v)
if i understand correctly the isolator is the thing where all of cables goes from batteries, i dont know exactle what kind of isolator is this but it is round with four bolts where the 2 positives and 2 negatives are placed.
something like this but with four bolts
http://www.randkproducts.com/images/31-7790006120.jpg
In all two battery systems there has to be a way for both batteries to get charged. In the simplest form both batteries are connected in series or parallel. This might be two 6V batteries in series for 12V or two 100A batteries connected in parallel to make 200A. The problem, particularly with the parallel connection is that slight variances in the batteries will cause one battery to discharge the other over time. Battery isolators fix that problem by not connecting the two batteries in parallel and still providing current to charge the two batteries when they need it. With the isolator in the system you now have two electrical circuits. How you connect the circuits is up to the designer of the dual battery system. Often selector switches or solenoids are used to select which (or in some cases combining both) batteries are connected to the main power of the truck. The device you linked looked like a solenoid.
If you did not design the dual power system - you will need to start to discover what it's intended purpose was and then how to operate it. Typical systems will do one of he following:
- Power generation for a camper
- Power generation for a winch
- Emergency starting backup
- Cold weather starting
Many of these systems will require action from the driver to operate - like combining the batteries for a large load or jump starting yourself should your main battery drain. It would be smart to get accustomed to any controls in the system and learn what they do and when to use them.
Since one battery is charged and the other flat - I would first put a volt meter on the flat battery while the truck is running and see if it gets a charge. If not you need to find if it had an automatic isolator and figure out why it is not providing current. You may find that it is a manual isolator which means that you will have to figure out how to connect it to the main circuit while you drive so that it will charge the second battery.
Since a dual battery setup is definitely custom, you will need to answer a lot of questions if you want to get good answers here.
This is the standard setup on the HDJ8#, 12volt system with a 24volt start. Take the question to the diesel tech forum and you will get a rapid and accurate answer.
Almost the entire world save the USA got dual batteries in the 80 series. Well except for the gas engine trucks but I have seldom seen any of those.
Tomorrow i will check exactly how the bataries are conected, ill take some photos, then i will be able to confirme you what kind of connection it is. my truck is equiped with factory electronic winch so i think that one of two bataries is for the winch.
PS. the indicator on the dash board indicates normal 14v.
