Batt. discharge light + ABS Light
NC
Could not find anything using the search function.
97FZJ80, 183K, owned for 7 years,
Replaced ALT about 3 years agoe.
On the way to work this morning the ABS light came on and the Battery Discharge Light came on. The voltage is reading at the top of the gauge.
The light went off for about a sec. and the gauge dropped to normal, but then went back up with the light.
What is the connection between the voltage and ABS?
Is it simply a bad alternator?
Thanks for the info.
EDIT:
The light stays off at idle. When the gas is pushed the gauge rises to above limits and the light comes on.
Regulator perhaps? Or is it part of the ALT?
If all your connections are sound, could be voltage regulator or could be the rotor coming apart, but the latter is a lower probability failure. Start with connections. Then pull the alternator and have it tested on the bench. Bitch of it is the alternator is in a retarded location and tough to easily pull and reinstall....good thinking Mr. Toyota.
X2 on the voltage regulator / just replace the alternator and let us know how it went
