Basic Questions
Hello all, this is my first post but I have been reading quite a bit on the site lately. I plan on buying an 95-97 very soon and building it into a competent family wheeling vehicle/driver for myself. I have been searching and reading but some info I just can't find or didn't search properly. So here goes:
I know I need to find one with factory lockers and I plan on putting on a Slee 4" or 6" Kit with 35" tires. What gears should I be putting in it to retain some power, it looks like 4.88 or 5.13? Also if I am going to rebuild the axles what other parts should I be looking into while I'm there? I saw that someone makes HD Birfield joints, what about the axle shafts, just looking to replace as much as I can or afford while I'm in there.
Also most of the trucks I have found have higher mileage, I've seen the threads on HGs and don't mind the work, I'm a fairly competent mechanic, but how many miles before looking into the bottom end should be addressed? What about general improvements to the performance? It seems like these trucks are pretty heavy and the 4.5L isn't exactly a powerhouse. Are there exhaust systems, intake setups, cam swaps, what are my options aside from blower or turbo? What about the transmission, do they make more heavy duty parts for rebuilds for them as well? And lastly the braking, I've read they only last 15k miles? Are there big brake options to look at?
Thanks a lot for any help and I'm sorry if some or all of these have been addressed previously, just point me in the direction of the correct threads and I'll be happy to read those.
If you search for it, you'll probably find it. I know it's a crappy answer, but do some more homework and you'll know the answer, not just what someone tells you.
Welcome! :flipoff2: <-- official 'Mud salute
Most guys who run 35's are happy with 4.88's.
The weak link is the birfields. Longfields or Newfields are available in the aftermarket, but they will wear fairly quickly with DD use.
OEM would be the best way to go, IMHO.
I'd start to think about it after 500,000 :D
Many have had good success with custom exhaust systems. As far as 91-92's go, the stock manifolds flow very well. Not sure if that applies to 93-97.
Intake setups aren't common, as the stock intake is very well designed. Also, K&N's are looked down upon. They don't work very well at all, and that's from personal experience.
Not much else... TRD makes a bolt-on supercharger kit, and Safari makes a turbo system, but they are both a pretty penny.
The transmission is heavy-duty enough as it is. These trucks were built for African expeditions, and then some. Flush and fill regularly and you'll be golden.
As you said earlier, these trucks are pretty heavy. My truck goes through a set of pads about every 10-13k...
Some have upgraded to 100 series (98-07) pads. You'll definitely want to search up on that, as well as LSPV adjustment.
Hope this helps! :cheers:
