Basic PM Questions
Houston, TX
After (near) flawless service for the last ten years and about 130k my truck threw a PO401 about two weeks ago. After reading some excellent threads here (example: RavenTai) on the EGR diagnosis I have narrowed the issue to the VSV, however will change the modulator too (still have the green one). This seems to have started a general PM bug in me, thus have some basic PM questions:
  • What is the recommended interval to change the plugs/rotor/cap? Mine were changed about 30K miles ago. Should wires be changed too or tested for resistance first?
  • Should the thermostat and the cap be changed every time the radiator is flushed? Currently, the flush is done about 12 months interval. However, the thermostat was changed about 2 years ago (~20K miles).
  • What is frequency to change the transmission/front and rear differentials/transfer case fluids? every 10K, 20K or something else?
Thanks for help.
* 30K on the plugs, wires, dist, rotor.
* Yes. 30K is in the operators manual. Every 2 years is probably sufficient, but many of us have OCD and are more aggressive about maintenance. :)
* I do Engine, Diff, TC oil changes at 5K. I do a BG44K treatment (injector cleaner) the tank before this service.
Here's my full maintenance schedule (from operators manual & various posts here):
Interval Service
5,000 BG 44K
5,000 Inspect Air Filter & Tuna Can
5,000 Inspect Ball Joints & Covers
5,000 Inspect Body/Chassis nuts & bolts
5,000 Inspect Brakes (F, R, E)
5,000 Inspect Steering Linkages
5,000 Lube Drive Shafts & Re-Torque
5,000 Lube Steering Knuckle
5,000 Lube U Joints
5,000 Replace ATF Fluid
5,000 Replace Diff Oil
5,000 Replace Engine Oil & Filter
5,000 Replace Transfer Case Oil
5,000 Rotate Tires
15,000 Inspect Exhaust pipes & mounts
15,000 Inspect Steering Box for leakage
15,000 Replace Air Filter & Tuna Can
30,000 Flush Brake Fluid
30,000 Flush Coolant
30,000 Inspect Fuel Lines, Tank Bands
30,000 Lube Drive Shaft Bushings
30,000 Pack Wheel Bearings (F, R)
30,000 Replace Belts
30,000 Replace Fuel Tank Gasket
30,000 Replace Spark Plugs, Wires, Dist, Rotor
60,000 Axle Service (F, R)
60,000 Inspect Valves
60,000 Replace Alternator Brushes
60,000 Replace Charcoal canister
60,000 Replace Hoses (including PCV & PHH)
60,000 Replace Starter Plunger
120,000 Replace Air Cleaner Hose
120,000 Replace Fan Clutch
120,000 Replace Idler Pulley
I can't say I do everything on schedule, but I do a lot of it. :)
Wow.....the list is quite comprehensive. Thanks.
Your schedule indicates 30K interval for radiator flush. I thought folks are more aggressive with this PM given the HG issue. Does frequent radiator flush help or is it just for peace of mind?
Once again...thanks for your help.
Depends on how much you drive your truck and the environment in which you drive it.
My truck sees about 5-10K miles a year.
Regardless, I do front and rear end jobs every year, along with fluids at every oil change (xfer, diffs, tranny, oil/filter).
I do radiator, plugs, wires, dizzy, and rotor once a year as well.
Brake fluid is once a year. PCV once a year.
I take the air filter and wash it after every "major" drive (wheeling trip/camping, etc.).
I drop the tranny pan and clean out the filter element and the pan once a year as well.
I do not do any synthetic fluids at all. Everything is diesel weight stuff (15w40/80w90/dino ATF, etc)....
Anyway, Hants has got a good list going. You do what you need to do for what you do with your rig....
-o-
You, sir, are a mental case.
-Spike
Why thank you Spike.
My truck might look like s*** but ask anyone around--undearneth the hood and under body is a very well maintained vehicle that has yet to overheat, break an axle or bust a birfield, have any issues with the tranny or xfer, has never had any issues ever starting up or stopping. It is, mechanically, almost perfect.
Now, damnit, I wish I had AC though....:rolleyes:
Just open the sun roof.....
Oh, wait-
