Baseline update for noobs
Little Canada, MN
I am not writing this post for the experts on this site that are amazing. I am writing this for the owners with little to no experience and more ambition than skill (and maybe tools). You can do more than you might think, just give it a try. There is great information on this site and in the FSM. You might want to double some of the time estimates on this site if you are truly a noob like me.
Each of the last 2 weekends I have taken on a baseline task – coolant flush/fill and plugs/wires/distributor cap/rotor. These were both first time PM items for me.
First my thoughts on the coolant flush/fill:
There is no way I thought using the radiator plug was going to give me a good result. It is in a difficult location with plastic and foam packed all around it. Turning it without breaking the plastic plug did not seem likely. I switched to using the output hose on the bottom passenger side of the radiator. The OEM hose clamps really make life hard. Plan on replacing the OEM clamp with a screw type hose clamp after it is removed. You will be much happier especially if you are doing a flush and therefore removing it over and over.
The tip on this site to get a 2’ socket extension for the block plug was brilliant. Do not think about the fact you cannot think where you will use this 2’ extension again. I spent around 6 bucks on it and it is a no brainer. It does line up perfectly in the DS wheel well.
The draining process is messy. No other way to say that, especially from the block. I used a large plastic tub used to mix concrete and I still could not get all the fluids dripping off the block. Have plenty of shop towels handy. The good news is the more you flush, the more the mess is getting “washed” with hopefully hot water.
I was a little surprised that Mr.T’s black coolant bottles do not have a clear sight line down the bottle. That would make the measurement much easier.
Total elapsed time = 8 hours. I did the initial drain, 5 flushes and the final re-fill. Drove the truck with heaters on high for a good chunk of time then let her cool for ~ 20 minutes before each flush. Managing all the liquid involved is a large part of the process. I had to re-use all the gallon jugs from the distilled water.
Thoughts on the tune-up:
98% of this job is simple and straightforward. I started with the distributor. It is easy to reach and a very simple swap. I changed the rotor also, but my original looked perfect. The rotor pulls straight out, but I had to give it a couple gentle taps to move it. The cap looked pretty good too. My wires were stamped 1997 – so they were original. Now they say 2010.
To work on the plugs I used two 2’x4’s strapped together. I was on my knees a long time on these boards. At the end I put on my knee pads, probably should have had them on the whole time.
I removed the entire air intake from the cleaner over to the intake manifold. I also removed No.2 PCV hose and the cruise control actuator cable. Obviously the 2 covers over the plug wires, but that was it.
Removing plugs 1-5 were easy. 4 was a mild PITA because of the cables I did not remove, but not bad. The OEM spark plug tool is really the greatest thing.
#6 is as bad as everyone says. Take your time and keep your cool. Have plenty of beer on hand to give you a reason to stop and think. The heater valve hoses mounted on the firewall are the biggest PITA. I ended up squeezing the hoses toward the firewall with my right hand while I extracted the tool with my left hand.
I could use some help on this explanation. I took it out for a drive after finishing. I believe the acceleration is much snappier – more responsive. I also used to run at 2200 RPM when doing a solid 55 mph. Now it seems to be down around 1900 RPM again at 55 mph. All my plugs looked normal, in fact 1, 5 and 6 I thought looked great after comparing to other pictures I have seen. I am overinflating the benefit of the tune-up because #6 was such a PITA or is this actual?
Total time = 4 hours. #6 was an hour by itself. I think I have seen 2 hours on the site.
FWIW - I have found a little duct tape to secure the sparkplug socket to the extension bar is helpful
