RockCrawler.com Bailey’s Scotch & Snatch
The Bailey’s Scotch & Snatch is designed for light duty applications with front and/or rear mounted winches. It was developed for the towing industry and is easily adapted for personal and recreational recoveries. Newer trucks made with composite or aluminum bodies with no anchor points, here’s your solution. It uses no chains or anchor points [...]
The Bailey’s Scotch & Snatch is designed for light duty applications with front and/or rear mounted winches. It was developed for the towing industry and is easily adapted for personal and recreational recoveries. Newer trucks made with composite or aluminum bodies with no anchor points, here’s your solution. It uses no chains or anchor points while improving stability during recovery on any surface type. It is a compact design for easy storage; folds to 14.5″ x 12.75″ x 4.5″ with 1 pin making it very easy to use. The Scotch & Snatch has corrosion resistant zinc plating and doubles as a wheel chock. It’s made*in the USA, start to finish. It allows you to use your truck to its fullest potential, doing more with less. There is an optional tire strap kit available for soft ground and/or larger tires.
Manufactured by Bailey’s Towing Accessories, Inc. Patent Pending
1422 Wall Road, Wake Forest, NC 27587
www.baileystowinginc.com
919-562-2984
Link
