Bad Temp sensor???
Minnesota
Bad Temp sensor??? P0402 Code
On colder days if I don't let my 1997 cruiser fully warm up before I start driving, I get a check engine light. If I let it warm up before driving (approx 10 mins) ,,,then the check engine light never comes on. Is this the sensor that triggers the check engine light?
I'm having a P0402 code. Something like excessive flow issue.
I've already replace my EGR valve and modulater.
Southern California
The code you have sounds incomplete, can you recheck the code and get the exact description so that we can try to diagnose the issue and also so that the others will chime in
Minnesota
I've got it reset for now, but once it comes back on, I will update it.
Minnesota
OK. So, I get a P0402 Code.
Any help would be appreciated. Thanks.
Minnesota
bump...
TrickyT
Hate that mud...
Mill Valley, CA
Use the search feature. P0402 has probably been covered as much as any other topic. I'll bet you can find at least 50 different threads.
Minnesota
Will do. Thanks.
Minnesota
Btw, I found out that the small pipe on the TB is clogged. I tried the paper clip thing, no go.
Next I will try the 2.5" 15 gauge finishing nail and small hammer trick. Gonna have to find that at the local hardware first. BUt.....
any other tricks that folks have tried and worked?
