bad p/s pump question
in the garage
my buddy has a 93' the p/s pump drives off the crank, right?
if the pump is bad, can the rig still be drivin (fj40 strong arm style) without internal or any other damage?
thanx for the help!
jim
If you just unbolt the pump from the block it will leave a big hole into the engine that will probably leak oil like crazy. In an emergency you could take the gear off the pump and bolt the pump back up. You need a 12-point 14mm socket and a gear puller to get the gear off. Or I suppose that you could make a temporary cover out of sheetmetal or plywood and bolt that to the engine in place of the pump.
Steering without the pump would have the same issues as any other power steering without a pump.
BUT YOU COULD DRIVE IT IF YOU HAD TO WITHOUT ANY ISSUES?
:frown: sorry bout the caps:frown:
Any more info on what, exactly, is wrong with it? You'd be surprised what a tablespoon of Downey fabric softener will do for a moaning pump. Seriously.
At the very least, spend the money on fresh fluid and see what happens. I replaced the fluid in mine last summer and got rid of 99% of the symptoms of a pump on its way out.
i'll pass that along to my buddy, if he has'nt already seen this.
whats the downey do?
This was one of Dan's tricks. Something about swelling the seals up inside the pump and stopping the moaning noise. It seemed to work temporarily in mine ~ I'd say 75% improvement immediately, but somewhat short-lived. As soon as I had time and it started moaning again, I replaced the fluid (RavenTai's method?) and I'm all good.
I still hear the PS once in a while when I'm wheeling, but that's about it. Pretty quiet day-to-day after about a year.
Just drive it...mine groans like hell and I don't feel like dealing with it to tell you the truth.
Seach under user name "jklubens"--Jimmy did a nice write up on rebuilding both the pump and the gear box. FYI, pump issues generally lead to or point to gear box issues, and vice versa as well.
