bad idle
Hey all,
my 80 has a bad idle when you first start it. It drives fine but when idleing it will jump around 400RPM and sounds as though there is a miss when it does. i have to manually bring the revs up.
It is a 94 1FZ-FE manual. im all out of ideas. i have changed the spark plugs so far.
any help would be great.
Ben
To add to this, I have a 94 and have a similiar problem. It did not start until I added the slee headlight harness. I think mine is a bad ground? Help!
Is the check engine light on?
Checking the air tube is a good one to check, I got a CEL when I had a loose battery cable, O2's could be going, Throttle body could use a cleaning...
search leads to plenty of reading.
IH8MUD™ Forums - Search Results
Good luck
