bad compression? leak down?
Longmont, CO
my 3B runs just fine.
however, when removing the flywheel I was surpised that I was able to spin the crank when undoing the flywheel bolts fairly easily. I'd expected that a diesel would be tough or impossible to turn over by hand.
the other thing is that I gave it a full revolution or more and couldn't really feel it turn over; the torque required to turn it was pretty constant, like maybe the cylinders were leaking down as fast as I turned.
does this sound normal, or completely broken? it runs fine, i might add, uses no oil, no smoke, etc.
As fast as you can turn the engine by hand it will not give full compression as the slow movement of the piston will allow some leakage.
The time to judge compression is with a gauge when the engine is warmed up and the oil is lubricating the bores.
Take all the glow plugs out except for the cyl your testing and turn the engine on the starter.
With no compression in 3 cyls it turns over really fast and gives an accurate reading on the gauge.
If your engine is all original it is bound to showing some signs of old age but ti sounds as if has some life left yet;)
