Backup light switch.
Colorado Boy-74-FJ40
I may grow older but I refuse to grow up!
Windsor Colorado
I successfully troubleshot mt backup light fuse blowing problem to the switch threaded into the top of the transmission directly behind the shifter. I took it out and the switch is shorting to ground internally. The rest of the backup light system has been rewired with new wires. I found a switch at a dealer and a couple online places for about 45 to 47 dollars...OUCH! Does anyone have any ideas? I was thinking about putting a lighted toggle switch on the dash that I can flip on when I want to back up that would illuminate the tail lights. I figure if I get one that lights up (red maybe) I wont forget to turn it off. I priced them to be 10 dollars or less. What do you field experts think?
A few people have commented on this recently. I ran a switch to the dash and rigged it on my old 40. If you are concerned about passing an inspection then you could call til you find a station that will pass it ;)
Rigged way of doin it but it works. SOR has used switches you can buy for cheap, just make sure you order the right one, they sent me the wrong one once.
Or just foot out the 45 bucks and do it right and forget about it ;)
All of us with a Toybox have to run a seperate switch as we have to destroy our backup switches to install the Toybox. Mine is already destroyed or I would swap with you. Find someone who is installing a Toybox and trade them your bum switch for their good one. Post up in the Wanted parts section.
I got a $2.99 lighted toggle switch and put it in last night, works great!. I'll just have to remember to flip the switch when backing up around the general public. It is lit red when activated and I mounted it on the dash just to the left of the ash tray so it is in my field of view. If I ever run across a transmission mounted switch for peanuts, I'll replace it. for now I'll take the cheap bastard route.
